2005 Honda Civic My fuses keep blowing
2005 HONDA CIVIC
40,000 MILES • 4 CYL • FWD • MANUAL
SPILLEDMILK4321
My Air conditioning went out on me while driving. I never had a problem with it. I found out it was a fuse blown (20). I inserted another one it blew as soon as I turned the air on. I tried a higher caliper fuse (25); it blew. I was told that it might be the relay switch. I have no idea where it is or what it looks like. My fuse box is under the hood. Any help or other suggestions of what might be causing the problem. When I inserted the (25) it stayed on for 10minutes before blowing. Thank You, Bryan
Aug 26, 2008 at 1:58 PM
KHLOW2008
  • 41,814 POSTS
Hi spilledmilk4321,
Which 20 A fuse are you refering to? Underdash for blower motor?
You need to check the blower motor for internal shorting.
Aug 27, 2008 at 4:17 AM
