Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Civic
Engine
Symptoms
Stall While Driving
2005 Honda Civic Engine stop when rpm goes down
2005 HONDA CIVIC
150,386 MILES • 4 CYL • FWD • AUTOMATIC
SELEGNA
MEMBER
1 POST
where can i locate an ECM/PCM from my engine? is this a cause why my engine always ceased when the rpm goes down and read only about 200
Nov 2, 2010 at 12:24 PM
KHLOW2008
Experienced Mechanic
Hi selegna,
The PCM would normally cause such problems.
What you are experiencing is more likely to be a malfunction in the ide controls.
If the Check Engine Lamp is not indicating, then getting the throttle body and Idle Air Control valve cleaned should solve the problem.
Nov 3, 2010 at 1:19 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
