2005 Honda Civic Air Filter
041.CHRIS
Air Conditioning problem
2005 Honda Civic 4 cyl Two Wheel Drive Manual
Any tips on how to replace the air filter, the screws don't want to seem to budge when I gently try to loosen them.
Thanks
Mar 8, 2010 at 10:53 AM
  • 75,988 POSTS
Dust and Pollen Filter Replacement (With Air Conditioning) The dust and pollen filters should be replaced every 30,000 miles (48,000 km) or 24 months whichever comes first. Replace the filters more often if the air flow is less than usual. 1.Open the glove box. Remove the glove box stop on each side, then hang the glove box down. 2.Remove the filter lid (A) from the blower unit, then pull out the first dust and pollen filter (B). Slide the second filter to the left, and pull it out.
https://images.2carpros.com/forum/automotive_pictures/12900_af_3.gif
3.Remove the filter (A) from the housing (B), and replace the filter. 4.Install the filters in the reverse order of removal.
Mar 8, 2010 at 11:51 AM
