2004 Honda Civic White smoke out the tailpipe and low pefor
84,000 MILES • 4 CYL • 2WD • MANUAL
FLICK6NINE
My oil needs changing and instead i put 3 qts of the proper oil in it untill i could get a oil change. After i did that i was driving it and there was ALOT of white smoke coming out the tailpipe and low performance. I would step on the gas and nothing would happen. I noticed the oils is dripping out the left side undercarriage of the car! Could it be the new oil blew the old filter up?! Cracked a gasket? What would cause the oil to leak out so much!
Apr 13, 2008 at 9:00 AM
  • 31,937 POSTS
Hi there,
you will have to give it a good wash down and run the engine to locate the leak, if you had to add so much oil i feel you have had a leak for some time, as for the smoke, white is usually coolant, so check the coolant level and if low have a head check done for a blown head gasket.
Mark (mhpautos)
Apr 13, 2008 at 10:45 AM
