2004 Honda Civic speedometer problems
GOLFNUTMIKE1
  • 2004 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 81,000 MILES
My speedometer doesn't like to work when it is cold. It will bounce for a second when you first start going, but then even if you get on the freeway it just sits at 0. If you drive for an hour or maybe even 45 min. And then come to a complete stop it sometimes will work. And sometimes after it is warm it will bounce for a few minutes and then when you get upto freeway speeds it will say you are going 20 when I know I am going around 80. Does this model have a cable or is it electronic? Is the cable maybe snapped in the middle? Should I just start car shopping:):):):):):)
Monday, May 3rd, 2010 AT 2:14 PM
KHLOW2008
  • 41,814 POSTS
Hi golfnutmike1,
The speedometer is electrically controlled with the Vehicle Speed Sensor sending the signals.
Most probably the VSS is faulty resulting in the symptoms described.
Wednesday, April 7th, 2021 AT 12:43 PM
