2004 Honda Civic Rad fan doesnt turn on unless manually tur
104,000 MILES • 4 CYL • FWD • AUTOMATIC
STKDTK
  • 20 POSTS
My car started overheating about a week and a half ago. It doesnt do it all the time, just randomly and with no real cause I can pin point. I am a P.I and sit for long periods of time and I have never had a problem? Yesterday I did an hour drive, sat for approx. five hours at idle, left and did about an another hour drive and everything was fine. Parked briefly, then started my car and it began blowing hot air through the A/C and overheating. Once I drove it, it stopped overheating, until I idled again then it would start after about ten minutes or so. Then I left again did about an hour and a half drive and eveything was fine again. I swapped relays and checked the fuses, piggybacked the fan, and bypassed the switched with a paper clip and the fan will not turn on unless I turn the fan blade manually, then it kicks on and stays on. My coolant is good and I've tried tapping the fan motor and that doesnt cause it to turn on either, only manually spinning the blade will work. I'm assuming that the motor is going out on the fan but just wanted a second opion. Also the fan doesnt come on when the A/c is turned on wither but the condensor fan does.
May 20, 2010 at 1:27 AM
  • 75,988 POSTS
Replace the radiator fan its defective
May 20, 2010 at 1:44 AM
