2004 Honda Civic no fluid
103,697 MILES • 4 CYL • FWD • AUTOMATIC
PAT25
My rear brakes are not getting any fluid to them. Thought it was master cyl., changed it still not fluid, will not bleed either
Oct 21, 2008 at 6:01 AM
KHLOW2008
  • 41,812 POSTS
Hi pat25,
Is your vehicle equipped with ABS? If yes you need to check the pump. Otherwise you need to check the proportioning control valve.
Honda uses diagonal system so if both rear brakes don't have pressure, it should be the PCV
Nov 7, 2008 at 7:15 AM
