2004 Honda Civic Heater causing car to overheat
2004 HONDA CIVIC
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
TFEATHERLY
My heater will only blow hot air when I am traveling at about 50mph or greater. When the car slows down, the air turns cold. While it is blowing cold air, the temperature rises, and when the air blows hot, the temperature drops to a normal level again.
Dec 19, 2009 at 9:37 AM
Check the thermostat and coolant level if okay -check heater core and radiator if its clogged-up
Dec 19, 2009 at 10:11 AM
