2004 Honda Civic Gauges on Dash Stuck
66,237 MILES • 4 CYL • FWD • AUTOMATIC
BIGRED510
For a few days the speedometer, the gas gauge, Engine Temp etc etc on the dash the light would flicker then the speed showed 0mph and fuel went to E while I would drive, then return to normal. Now the gas gauge is stuck on 3/4 full tank and speed around 40mph when I turn the car on and has not changed for about a week now. The gas light still comes on when gas is low, but speedometer and gas gauge are stuck. Any ideas what it could be?
Sep 9, 2009 at 9:50 AM
KHLOW2008
  • 41,812 POSTS
Hi BigRed510,
Problem is most likely caused by loose wire connectors somewhere between power source and meter cluster. You would have to remove the meter cluster to check.
Sep 13, 2009 at 2:23 AM
