2004 Honda Civic Engine Turn Over
106,000 MILES • 4 CYL • FWD • AUTOMATIC
VYSONG
just the other day I left early in the morning to run an errand and the car turned over as usual, then when I shut off the car and came back after running my errand, the car would not turn over. The car is getting full power to everything (radio, heater, windshield wipers) and the battery is only about a year old. I turn the key and I get one click, but after trying a couple more times the engine finally turns over. This seems to happen intermittently throughout the day, sometimes it will turn over immediatley and other time it takes a couple tries? What could cause this problem?
Feb 18, 2009 at 6:38 PM
BMRFIXIT
  • 19,053 POSTS
Suspect a bad starter
should have it checked and replaced
check the wiring on the starter solenoid
(replace starter)
Feb 18, 2009 at 10:36 PM
