2004 Honda Civic DOOR LOCKS / SIDE AIR BAG LIGHTS
2004 HONDA CIVIC
55,000 MILES • 4 CYL • FWD • MANUAL
SHAYDOGG
My driver side door lock does not work and now I have my side air bag light going on and off at times. Can these be related issues from the same source? I'm hearing things about a teranmitter being bad or an actuator. Any suggestions?
Sep 11, 2008 at 4:36 AM
KHLOW2008
  • 41,814 POSTS
Hi shaydogg,
You need a scan to find out what is wrong with the SRS system.
What is wrong with the driver side door lock?
Sep 13, 2008 at 6:14 AM
SHAYDOGG
I cannot lock or unlock my driver side power door lock with my sensor. this happens on the driver side only, the passenger side door unlocks and locks with my key pad. Any siggestions?
Sep 15, 2008 at 9:26 PM
KHLOW2008
  • 41,814 POSTS
Hi shaydogg,
Most probably the door lock actuator is faulty.
You need to remove the door panel to get at the actuator.
Unplug the wire socket and bridge with a testlamp, operate the lock/unlock. If the lamp lights up, the actuator is faulty and needs to be replaced.
Sep 16, 2008 at 12:05 AM
