2004 Honda Civic atf change
97,000 MILES • 4 CYL • FWD • AUTOMATIC
SANDYPANDYBYERS
  • 5 POSTS
Do I have to use genuine Honda ATF-Z1? How much tranny fluid do I need? Also do I need a drain plug gasket? And can I do a tranny flush or do I have to drain it and fill it 3 times like the manual says?
Oct 27, 2009 at 3:15 AM
SERVICE WRITER
  • 9,123 POSTS
When it comes to hondas, I would use the honda fluid. this is a cvt. You can flush or drain and fill. Drain and fill is easy enough. Should replace the gasket.
3.3 qts
Oct 27, 2009 at 3:41 AM
