2004 Honda Civic atf change
SANDYPANDYBYERS
  • 2004 HONDA CIVIC
  • 4 CYL
  • FWD
  • 97,000 MILES
Do I have to use genuine Honda ATF-Z1? How much tranny fluid do I need? Also do I need a drain plug gasket? And can I do a tranny flush or do I have to drain it and fill it 3 times like the manual says?
Tuesday, October 27th, 2009 AT 10:15 AM
SERVICE WRITER
  • 9,123 POSTS
When it comes to hondas, I would use the honda fluid. This is a cvt. You can flush or drain and fill. Drain and fill is easy enough. Should replace the gasket.
3.3 qts
Tuesday, October 27th, 2009 AT 10:41 AM
