2004 Honda Civic ALIGNMENT
81,000 MILES • 4 CYL • 2WD • AUTOMATIC
FALCON2834
I have a vibration in my steering wheel when i get above 55 mph. originally i brought my car into the shop to get the alignment done. when i brought it in it was vibrating really bad to where it was shaking the entire car and it was also pulling to the left. I had the tires balanced and the alignment done and also the rotors plained. The vibration is just in the steering wheel now and also the car is pulling a little bit to the right. Could it be that the alignment was over corrected alittle or could it be something else?
Oct 20, 2009 at 3:42 AM
F4I_GUY
  • 3,302 POSTS
If the steering wheel is still shaking you most likely have a bad tire or bent rim. Even though they made them balance, doesn't mean something isn't wrong with the tire/rim itself.
If the vehicle pulls to the left, either they didn't do a proper alignment or your tire pressures are adjusted improperly.
Oct 20, 2009 at 2:19 PM
