2004 Honda Civic 2 different opinions
85,000 MILES • 4 CYL • FWD • AUTOMATIC
HONDAGIRLSASKATOON
hello,
I've had intermittent problems with my power steering for a couple years. Every now and then it feels like I have no power steering, especially when it is cold out (but it also happens in the summer) and when making tight turns in a parking lot.
When it started the mechanics couldn't find anything wrong with it, and told me just keep driving until I can't take it anymore, and get a new steering column.
So now it's getting worse, I took it to a garage and they told me I need a new rack and pinion, and quoted me $960.
For a second opinion I took it to Honda, and they told me it needed a new steering pump, and quoted me $650.
I am assuming Honda is right, since they know the cars, but with two different opinions I am worried that mabie the pump won't be enough and I have to go back and get the rack and pinion as well, costing me even more.
Should I take it to a third mechanic? Or does rck and pinion mean the same thing as a pump?
THANKS for your help!
Jan 18, 2010 at 7:19 AM
BILLYMAC
  • 2,204 POSTS
Hi
Your honda dealer is right. and no pump is not the same as rack. but here is a logical explanation as to why it is the pump. very simple a bad rack is a bad rack, it will not get better. if it is bad it is bad until it is replaced.
PUMP--Now the pump builds pressure it uses these ports called veins they can change size with heat or cold , when they do pressure is high or low causeing hard steer condition.. make sense
ty BILLYMAC
Jan 18, 2010 at 7:37 AM
HONDAGIRLSASKATOON
what a simple explanation ~ that helps immensly, thank you!
Jan 18, 2010 at 8:03 AM
