1997 Honda Civic
1997 HONDA CIVIC
HONDA_97
1997 Honda Civic 4 cyl Automatic 122000 miles
My car has never had any major problems. I just recently got my timing belt and water pump replaced for maintenance, and about a week later started hearing a strange noise coming from what seems to be the front driver's side. It's a loud, high pitched noise that sound like metal being scrapped against metal. The strange thing is that when I press my breaks, the noise gets higher in frequency, and if I slow down more, it stops all together. Nothing seems to trigger it, I can just have started driving or be going down the highway and it starts. Speeding up just seems to make the noise worse. One mechanic told me the car needs a rack and pinion replacement, but I've never had problems steering, and there certainly is no 'clunking' noise. Got any ideas as to what this could be? Should I go ahead with the rack and pinion or is it more likely some other problem? I'm poor! Any ideas? Thank you sooo much for your time!!
Apr 8, 2009 at 5:15 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would start with having the brakes inspected for wear, make sure that they pull the brake pads out and inspect any wear tads that may be touching the rotor, start here and report back any findings, i feel its not the steering rack.
mark (mhpautos)
Apr 8, 2009 at 5:20 PM
I agree with my coworker from down under-sounds like the wear indicator on the pads are grinding against the brake rotor
Apr 9, 2009 at 12:03 AM
HONDA_97
Thank you so much! What prompt responses!!
I will get it looked at today and let you know.
Apr 9, 2009 at 5:20 AM
HONDA_97
Thanks again! That's exactly what it was. Waay cheaper to fix and no problems out of my car! :)
Apr 16, 2009 at 10:31 AM
  • 31,937 POSTS
Hi there,
Great result! thank you for using 2carpros, pass the word and post again when you ever need help.
Mark (mhpautos)
Apr 16, 2009 at 11:18 AM
