2004 Honda Civic
2004 HONDA CIVIC
98,000 MILES • 4 CYL • FWD • AUTOMATIC
SANDYPANDYBYERS
  • 5 POSTS
How do I change the tranny fluid in my car, will I have to drop the pan or just pull out the drain plug? I am also unsure if my car is front wheel drive, does that make a difference? It is a 2004 Honda Civic SI...thank you in advance!!! :)
Oct 29, 2009 at 8:37 AM
F4I_GUY
  • 3,302 POSTS
Your vehicle is front wheel drive.
There is no pan, there is however a drain plug. You have to remove the drain plug to drain the fluid!
NOTE: This will only remove about 30%of the fluid in the system. If you want all of the fluid removed you have to get a transmission flush done at a shop.
Oct 29, 2009 at 9:08 AM
