2003 Honda Civic Repairs Needed - Estimate
CSAM
  • 2003 HONDA CIVIC
2003 Honda Civic Manual
Hi, My spouse has just passed away and the list below is what is needed to fix the car (Manual 2003 Honda Civic LX). I would be grateful knowing the approximate breakdown cost estimate of the following, please & thank you:
- Clutch is burned out, needs to be replaced.
- Clutch plate and bearings are burned out, need to be replaced.
- Brakes need service.
- Emergency brake does not hold - needs service.
Tuesday, April 6th, 2010 AT 2:58 PM
SERVICE WRITER
  • 9,123 POSTS
My condolences.
The labor on the clutch is about 4-5 hours approximatley. So at $100/hr the labor would be $4-500. The clutch kit can vary, but you want to use a new one not remanufactured.
The clutch kit with mark up will be in the $4-450 area depending on brand and markup. To machine the flywheel another $50 if needed.
The brake situation isn't clear as to what is being done. If they are rear DRUM brakes, then perhaps adjusting them will resolve the parking brake and raise the brake pedal. This would be around 35-50$ depending on the shop. Usually it is a set fee, and it will vary.
Wednesday, April 7th, 2010 AT 8:24 PM
