2003 Honda Civic p0134
JDMHONDA
Computer problem
2003 Honda Civic 4 cyl Two Wheel Drive Manual
I drive a 2003 Honda Civic Hybrid. My engine light was on so I drove to my local dealer and they pulled the code p1166. They advised me to replace the o2 sensor. The oem type was 341 each (uses 2). I've decided to use an universal bosch (called bosch and they said it was compatible). Both o2 sensor were installed and the code was cleared. 5 miles lates a p0134 code showed up? It's also related to 02 sensor. I dont know what I do next. Bosch said connections were fine...
May 26, 2008 at 3:28 AM
KHLOW2008
  • 41,812 POSTS
Either the replaced sensors are not compatible, connected wrongly or defective or there is some wiring fault from sensor to ECU .
May 26, 2008 at 3:38 AM
