2003 Honda Civic oil use
220,000 MILES • 4 CYL • 2WD • MANUAL
RHODESER
I have 2 differnet opinions, one said valve seals and the other said rings, is there away to tell if I need to replace the valves seals or if my rings are bad,How can I tell which is my trouble?
Jul 29, 2010 at 3:29 AM
KHLOW2008
  • 41,812 POSTS
Hi rhodeser,
There are no confirm means of determining which is the cause but Honda engines seldom have problerm with the rings. The seals would be more likely. If you need to replace the rings, then it is likely the valve seals have to be replaced as well.
Jul 31, 2010 at 7:16 AM
