2003 Honda Civic No Heat, Diagnostic Says Short Circuit
SAM83
Heater problem
2003 Honda Civic 4 cyl Front Wheel Drive Automatic 100k miles
My Civic's heat has stopped working. The self-diagnostic reports DTC #8 - A short in the air mix control module. When I turn the temperature knob all the way hot or cold, the motor under the dash board moves back or forth, but doesn't operate completely.
Is it time to start pulling out wiring to find a short? Any tips?
Thanks
Jun 2, 2010 at 6:04 AM
KHLOW2008
  • 41,812 POSTS
Hi Sam83,
It is never good to go in blindly to check a problem. I have sent the diagnostic files to you, hope it is helpful.
Jun 4, 2010 at 8:20 PM
SOLIDPWDER
could you please send me the same files you send Sam83. I got a 03 civic to and the temp gauge is just under half and when I turn the heat on, I get cold air. I just replaced the thermostat and still got nothing. Any information would help
Solidpwder@sbcglobal.net Oh what are the chances a heater core would be bad?
Jun 7, 2010 at 12:15 PM
KHLOW2008
  • 41,812 POSTS
Hi Solidpwder,
I have sent the files to you. It is either the heater control valve or air mix motor/control module.
Jun 8, 2010 at 1:10 AM
