2003 Honda Civic Need Diagnoses...
2003 HONDA CIVIC
75,000 MILES • 4 CYL • 2WD • MANUAL
SMITHKM2
I have a little bit of performance additions on my Civic such as a turbo but I do not think its because of my mods.
When I let of the clutch and start to accelerate from a top I get this little power loss you can feel it jerk a little but after I get out of first gear it stops and drives perfect with no problems I was thinking maybe my Throttle positioning sensor was going bad but I have no Pending codes or no check engine light or any indication what might be happening. could I just be hitting a lean spot at this low rpms you think? it happens almost immediately when rising up in speed from a complete stop only.
Feb 22, 2010 at 9:35 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 22, 2010 at 10:00 PM
