I've noticed a wet spot on the carpet of the drivers side door. What can be causing this leak and how can I fix it?
Feb 8, 2010 at 10:35 AM
✓Experienced Mechanic
I would recommend removing the door panel and check it out. THere should be a plastic sheeting between the door panel and the door. If it has been removed, it could be the problem.
Feb 9, 2010 at 2:04 PM
RONI1981
MEMBER
I made a mistake, it driver sides FLOOR there is a patch of water right next to the trunk and gas release. Any ideas there?
Feb 10, 2010 at 12:37 AM
Check the rubber weather stripping along the door and also, check under the car for any dammage or rust.
