2003 Honda Civic Leak driver side floor
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
RONI1981
I've noticed a wet spot on the carpet of the drivers side door. What can be causing this leak and how can I fix it?
Feb 8, 2010 at 10:35 AM
  • 110,244 POSTS
I would recommend removing the door panel and check it out. THere should be a plastic sheeting between the door panel and the door. If it has been removed, it could be the problem.
Feb 9, 2010 at 2:04 PM
RONI1981
I made a mistake, it driver sides FLOOR there is a patch of water right next to the trunk and gas release. Any ideas there?
Feb 10, 2010 at 12:37 AM
  • 110,244 POSTS
Check the rubber weather stripping along the door and also, check under the car for any dammage or rust.
Let me know what you find.
Feb 10, 2010 at 10:14 AM
