2003 Honda Civic DRL Lights not on, fuse blow.
2003 HONDA CIVIC
146,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHALO
  • 11 POSTS
My DRL Lights not come on because a fuse 10Amp. was blow up do you know how found the short circuit, thanks[img:d285bc45e4]http://www.2carpros.com/forum/automotive_pictures/341063_image484_1.gif[/img:d285bc45e4]
Jul 16, 2010 at 9:01 PM
KHLOW2008
  • 41,814 POSTS
Hi Chalo,
Which 10 A fuse is blowing?
Does replacing with a new one result in it blowing too?
Jul 17, 2010 at 9:13 PM
CHALO
  • 11 POSTS
yes the fuse was blow again and again must be a short circuit .
Jul 18, 2010 at 11:37 PM
KHLOW2008
  • 41,814 POSTS
You did not specify which fuse is blowing.
Was any repairs carried out prior to this happening?
Any impact damages?
Jul 19, 2010 at 1:10 AM
CHALO
  • 11 POSTS
Hi I don't remeber exactly what is the number but there is two fuses the one what is hot all the time this one is blow, i think is the number 11 or 12
https://images.2carpros.com/forum/automotive_pictures/341063_image484_2.gif
Jul 19, 2010 at 10:51 AM
KHLOW2008
  • 41,814 POSTS
Fuse # 12 ( 7.5 A) is specifically for the Multiplex and DRL Control Unit.
Unplug the DRL and Multiplex control unit and retest if the fuse blows, test the Yellow/Red wire ( terminal # 12 of DRL Control unit for short ciucuit to body.
Jul 20, 2010 at 12:17 AM
