2003 Honda Civic control system leakage (EVAP canister syst
70,000 MILES • 4 CYL • FWD • AUTOMATIC
DIONTHEHILL
2003 civic check engine light indicates problem. Before taking care to Honda dealer, would like to know approximate cost to fix problem.
Mar 22, 2009 at 3:47 AM
F4I_GUY
  • 3,302 POSTS
Just because you have the DTC it doesnot mean we know exactly what is wrong with the vehicle.
They will perform a smoke leak detection diagnosis which is about an hour diagnosis. If it takes longer to find the leak, they will charge you more. So it's hard to tell you how much they will charge, it all depends on what is leaking.
Roughly, look to spend a minimum of 1 hour strictly for diagnosis. Then you will pay labour and parts for whatever the faulty item is.
Goodluck.
Mar 22, 2009 at 5:41 AM
