2003 Honda Civic clutch problem
2003 HONDA CIVIC
100,000 MILES • 4 CYL • FWD • MANUAL
QQ420
I just change my hole clutch system and i'm still not getting any pressure to my throw out bearring i bleed it and I even change my throw out bearring and pressure plate is there a certain way to set the throw out bearring and im not getting any pressure to the pedal. I change my clutch slave and the clutch master.
Oct 2, 2008 at 7:47 PM
CLARENCET
  • 7 POSTS
try these steps they may help you with your problem
1) bench bleed the clutch master cyld.
once installed have another person pump the clutch pedal then go on to bleed the slave cyld make sure to keep the resivor on the master cyld full or you will ruin it that should take care of it.
also make sure to see if there is an adjustment screw on the clutch master thats attached to the clutch pedal
almost forgot are you sure that the release bearing did not come off the clutch fork that will also cause this problem
Hope this helps
Oct 9, 2008 at 5:18 PM
