2003 Honda Civic
JUAN TORO
Engine Mechanical problem
2003 Honda Civic 4 cyl Two Wheel Drive Automatic 110.00 miles
I would like to change the timing belt, I like to kow
the size of the socket, in order to remove the Crankshaft nut and the Camshaft nut
Feb 13, 2010 at 6:40 AM
KHLOW2008
  • 41,812 POSTS
Hi Juan Toro,
The crankshaft bolt is either 17 r 19 mm depending on the type used. You would need a high torque impact wrench to remove the bolt.
For the camshaft pulley, it is 12 mm.
Feb 13, 2010 at 10:01 PM
