2003 Honda Civic
JUAN TORO
  • 2003 HONDA CIVIC
Engine Mechanical problem
2003 Honda Civic 4 cyl Two Wheel Drive Automatic 110.00 miles
I would like to change the timing belt, I like to kow
the size of the socket, in order to remove the Crankshaft nut and the Camshaft nut
Saturday, February 13th, 2010 AT 2:40 PM
KHLOW2008
  • 41,814 POSTS
Hi Juan Toro,
The crankshaft bolt is either 17 r 19 mm depending on the type used. You would need a high torque impact wrench to remove the bolt.
For the camshaft pulley, it is 12 mm.
Sunday, February 14th, 2010 AT 6:01 AM
