2002 Honda Civic transmission repair
35,000 MILES • 4 CYL • FWD • AUTOMATIC
MENOCAL67
i have a problem whit code 1773
Jul 5, 2010 at 7:28 AM
KHLOW2008
  • 41,812 POSTS
Hi menocal67@yahoo.com,
DTC P1773: PROBLEM IN A/T CLUTCH PRESSURE CONTROL SOLENOID VALVE B CIRCUIT (2001-03 MODELS)
NOTE:
• Record all freeze data before you troubleshoot.
• This code is caused by an electrical circuit problem and cannot be caused by a mechanical problem in the transmission.
1. Disconnect A/T clutch pressure control solenoid valve B connector (2P).
2. Measure A/T clutch pressure control solenoid valve B resistance at the solenoid valve connector.
Is the resistance 3 10 Ω ?
YES - Go to step 3.
NO - Replace the A/T clutch pressure control solenoid valve A and B.
3. Disconnect PCM connectors B (24P) and C (22P).
4. Check for continuity between PCM connector terminal B16 and body ground, and between terminal C8 and body ground.
Is there continuity?
YES - Repair short to ground in the wires between PCM connector terminals B16, C8, and the A/T clutch pressure control solenoid valve B.
NO - Go to step 5.
5. Connect A/T clutch pressure control solenoid valve B connector.
6. Measure the resistance between PCM connector terminals B16 and C8.
Is the resistance 3-10 Ω ?
YES - Go to step 7.
NO - Repair loose terminal or open in the wires between PCM connector terminals B16 and C8, and the A/T clutch pressure control solenoid valve B.
7. Disconnect PCM connector A (31P).
8. Check for continuity between PCM connector terminal A23 and body ground, and between terminal A24 and body ground.
YES - Check for loose terminal fit, and repair if necessary. Update the PCM if it does not have the latest software, or substitute a known-good PCM, then recheck. If the symptom/indication goes away with a known-good PCM, replace the original PCM.
NO - Repair open in the wire between PCM connector terminals A23, A24, and ground (G101), or repair poor ground (G101).
© 2008 Mitchell Repair Information Co., LLC.
Feb 3, 2019 at 4:37 AM
