2002 Honda Civic Squeaking Sound from Air Conditioner
106,000 MILES • 4 CYL • FWD • AUTOMATIC
REFPOMAN
When car is at idol and the A/C is on...when the A/C compressor kicks in I get a squeaking noise. When the A/C compressor disengages, it goes away or when I increase the rpm's or start to drive. Any ideas of what might be happening?
Jun 27, 2008 at 7:58 AM
DOCFIXIT
  • 18,828 POSTS
Worn or lose drive belt
Jun 27, 2008 at 8:13 AM
REFPOMAN
Is the drive belt the same thing as the timing belt? Belts and water pump were changed at 83,000 miles. How do I go about getting the drive belt tightened?
Thanks!
Jun 28, 2008 at 12:21 PM
KHLOW2008
  • 41,812 POSTS
Hi refpoman,
No, the tming belt is inside the cover and will not squeak as the are toothed.
If your model uses a single serpentine belt, it is self adjusting, you need to replace the belt or tensioner bearing.
If it has 3 belts, then you will find the adjusters for
Alternator on the bracket.
Power steering on the pump.
AC on the idler bearing.
Jun 28, 2008 at 3:12 PM
HONDACIVICOWNER2001
Hello, I have a 2001 Honda Civic Coupe with the EXACT same problem. Have you tried adjusting your drive belt yet? If so, did this fix the problem? Please keep me updated!!
Jul 13, 2008 at 4:40 PM
