2002 Honda Civic smoking
2002 HONDA CIVIC
101,000 MILES • 4 CYL • FWD • MANUAL
ECLIPSE69
I own a 2002 honda civic. I have maintained all service tining belt replaced,and new transmission. I was driving 65 mph on the highway when i lost all power to the gas peddle. I thought it might be the the fuel pump had it towed to the mechanics shop. The car sat over the weekend and was looked at by mechanic and the car started right up. my mechanic pulled the air filter cover off and informed me that there was smoke coming from under the valve cover through the breather hose. He told me that I might have a cracked cylinder or other internal engine problems. does this sound right? I have not had a overheating problem and dont know what to do next any help would be appreciated Thanks
May 28, 2008 at 4:49 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
There are a number of tests that your mechanic can do to determine the cause of this fuming. The normal reason is worn piston rings, this can be tested with a compression test or a leak down test. This should be done first.
mark (mhpautos)
May 28, 2008 at 5:13 AM
