The AC on my Honda Civic starting failing intermittently so I went to an AC shop for diagnosis. The coolant was fine, no leaks. They said the problem was the compressor but they wanted a lot to fix it so I went for a second opinion. This other guy was a neighborhood garage owner and he wasn't so sure it was the compressor. He jumped around the terminals on the ECU and the AC worked. He thought it was the ECU. Either way it's an expensive repair so I want to make sure it's the right part, because I'll order it online and have the neighborhood mechanic install it. What do you think? Is there anyway to know for sure?
May 10, 2008 at 8:36 AM
