Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Civic
Engine Cooling
Cooling Fan
Not Working
2002 Honda Civic radiator fans
2002 HONDA CIVIC
130,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHN R. CHEEVERS
MEMBER
1 POST
fans not working,replace fan motor fans worked for about a month, then worked on and off, now not working. could it be the relay switches?
Nov 17, 2009 at 8:17 AM
KHLOW2008
Experienced Mechanic
Hi John,
Yes, it is possible the fan relays are intermittently failing due to bad contacts internally.
Check wire harness and relay connectors for signs of overheating which would cause the contact to go bad.
Aug 9, 2019 at 10:46 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
