fans not working,replace fan motor fans worked for about a month, then worked on and off, now not working. could it be the relay switches?
Nov 17, 2009 at 8:17 AM
KHLOW2008
✓Experienced Mechanic
Hi John,
Yes, it is possible the fan relays are intermittently failing due to bad contacts internally.
Check wire harness and relay connectors for signs of overheating which would cause the contact to go bad.
Aug 9, 2019 at 10:46 AM
