2002 Honda Civic radiator
19,300 MILES • 4 CYL • FWD • AUTOMATIC
SHEILA MINDZORA
  • 5 POSTS
i would like to know if my radiator is clogged will it back up in overflow if too much in radiator? i overheated and have checked every possible things. it doesnt overheat but i lose fluid and there's no water in oil and nothing come out of exhaust. all hoses are fine. please help me!!!
Jun 17, 2010 at 6:39 AM
  • 31,937 POSTS
A blocked radiator will show a few symptoms, depending on how may core tubes are actually blocked, normally you will see the temp gauge penduluming a little, you will get coolant over flowing with the filler cap off, the bottom of the radiator will feel some what cooler than normal, radiators need to be core cleaned and a simple back flush is not good enough.
Mark (mhpautos)
Jun 17, 2010 at 11:41 PM
