2002 Honda Civic power windows
119,000 MILES • 4 CYL • FWD • AUTOMATIC
KBAILY
the passenger side power window switch started to smoke on the drivers side as I tried to lower the window. does this mean that the motor is blown or a simple fuse? the window was having problems going up and down before - just moving a bit slower than the drivers.
Jun 23, 2010 at 9:28 AM
KHLOW2008
  • 41,812 POSTS
Hi kbaily,
It could be a failing motor, a bad switch or restrictio of the glasses causing excessive resistance for the glass to move up.
Check the door glass channel for crumpling and try spraying some water onto the glass runchannel to see if the movement speed increases.
Jun 28, 2010 at 7:02 AM
