2002 Honda Civic Oil leak from valve cover area
2002 HONDA CIVIC
99,500 MILES • 4 CYL • 2WD • AUTOMATIC
GWAITS
There is a small oil leak coming from behind a black plastic circle at the left end of the valve cover. How do I repair that?
Feb 24, 2009 at 1:55 AM
F4I_GUY
  • 3,302 POSTS
Picture please? There is no plastic piece on the valve cover that would leak oil.
Feb 24, 2009 at 9:31 AM
GWAITS
Maybe I did not phrase my question well, but you are wrong, there is a hard black plastic O-Ring on the left end of the valve cover. I went by the Honda dealer, purchased the $10.43 part, popped the old one out with a screwdriver, snapped the new one in place, and the oil leak is stopped. Not sure but my guess is that this O-Ring is a Honda designed feature to pop early rather than have the valve cover gasket blow under pressure. Thanks for your suggestion however, I think I will hunt me up a manual for the future, but these are great cars, not expecting anything to go wrong!
Feb 24, 2009 at 10:17 PM
F4I_GUY
  • 3,302 POSTS
This is the cam end plug in the side of the cylinder head correct?
Anyways, glad you solved your problem.
Feb 25, 2009 at 11:19 AM
