main relay
DAVIDTMYERS900
Thank you for responding about where the main relay is located in my 2002 Honda Civic Lx. Do these two relays have computer boards where in I can pop the casing and check the solder joints or am I way off base?
Oct 5, 2010 at 11:27 AM
KHLOW2008
  • 41,812 POSTS
What is the problem you are encountering? The relays are normal relays with no electronic circuit boards and if bad, they would have to be replaced. Here is a guide to help you test the relay https://www.2carpros.com/articles/how-to-check-an-electrical-relay-and-wiring-control-circuit Next to PGM-FI relay 1 is # 2, located behind glove box.
https://images.2carpros.com/forum/automotive_pictures/192750_DashComp02CivicFig02_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_PGMFIRelay02CivicFig95_1.jpg
Larger images below!
Oct 8, 2010 at 1:54 AM
DAVIDTMYERS900
2002 Honda Civic
Can you please tell me where the main relay is located on my 2002 Honda Civic Lx? Thank you, David
Sep 22, 2017 at 3:02 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
there are 2 main relays, both are behind the glove compartment box.
DAVIDTMYERS900
Electrical problem
2002 Honda Civic Front Wheel Drive
I have a 2002 honda civic lx. I have been jump starting my car for a while now and because i don't have a job right now, I've been forced to try and fix it myself. When I turn my key I get nothing but a click. When I followed the sound of the click it was coming from the fuse box under the hood. To the touch the click was coming from a fuse or relay called Omron G4R-H-22 12v 0951D7 I'm not sure what that is but could that be my problem? It's not my starter or battery, both are good. Please help a poor old man and I'm sorry I can't donate any $ at this time. Thank you David
MMPRINCE4000
  • 8,548 POSTS
There is a starter relay, try to find one at a junk yard.
You can have the battery and alt. tested for free at most autoparts stores.
If battery is original, then it is due to be changed.
