2002 Honda Civic it makes noise when pulling out in 1,2,3
CARLITILLOS1
Transmission problem
2002 Honda Civic 4 cyl Manual 155000 miles
it sounds like if the fan was hitting but there not i checked for any sings that would indicate rubbing but no sings so i think it has something 2do with the tranny because when its making that noise i put the clutch in and it stops but i dont think is the cluth cause it dosent make any noise when its in the car is completly stoped and the ingine is running
Jul 22, 2010 at 8:32 PM
EDWARD.S
  • 166 POSTS
Hi, Was The clutch Ever replaced? Sounds Like You May Have A Bad Throw Out Bearing.This Bearing Can Go bad Is The clutch Is not Adjusted right. Also Check The Trans Fluid .
Hope This Helps You,
Good Luck
Edward S.
Jul 22, 2010 at 10:38 PM
