2002 Honda Civic Heater
MURDODEBB
Heater problem
2002 Honda Civic 4 cyl Two Wheel Drive Manual
heater not blowing. Have checked fuses but no joy.
Jan 6, 2010 at 2:46 AM
KHLOW2008
  • 41,812 POSTS
Hi murdodebb,
I would suggest checking the blower motor. Give the blower housing under the glove compartment some banging with your fist and retry, if it works, the motor is due for replacement as the carbons have worn off.
If not, unplug the blower motor 2 pin connector and test for battery voltage with ignition switch ON. If voltage is present, ( note wire color or terminal point) plug it back in and use a jumper wire to ground the wire with no battery voltage when connector was disconnected. If blower works, we would need to go into diagnostics with the control panel or power resistor.
If blower motor fails to work, the motor is bad and requires replacement.
Jan 11, 2010 at 5:25 AM
MURDODEBB
[quote:23ab1e946c="KHLow2008"]Hi murdodebb,
If blower motor fails to work, the motor is bad and requires replacement.[/quote:23ab1e946c]
Jan 13, 2010 at 3:07 AM
KHLOW2008
  • 41,812 POSTS
You did not write anything in the post. Have you done as suggested?
Jan 13, 2010 at 3:18 AM
