2002 Honda Civic Heat Shield
140,000 MILES • 4 CYL • 2WD • MANUAL
SALLYBUG
My heat shield that protects the catilytic converter makes a metallic vibration noise when the car shifts, not to bad , only for a few seconds. Had it looked at and it would require replacing the whole unit, at a cost of over 750. Does this sound right? Cant it be welded?
Sep 25, 2008 at 1:44 PM
2CARPRO JACK
  • 11,533 POSTS
If it is just the heat shield you can try using a clamp to hold it or have it tack welded to the cat.It may be the cat rattling internally is why you were quoted that much to fix it
Sep 26, 2008 at 11:03 AM
SALLYBUG
The Mechanic did say it was the heat shield that was making the noise, that everything else looked fine, but perhaps I need to get a second opinion just to be safe.
Thanks so much!
Sep 26, 2008 at 11:33 AM
2CARPRO JACK
  • 11,533 POSTS
I would 750 sounds a little steep for fixing a heat shield
Sep 26, 2008 at 11:35 AM
