the headlights, dome light and instrument pannel flicker while the car is at idle or while driving this happens when the car is at normal operating temp, the lights stop flickering when I power on the a/c. I have also noticed that the lights flicker to same same pase as the cars idle speed. I have a brand new alternator installed and a new battery oe specific size, I have tested the battery and alt output myself and had a local autoparts store test also, results are system working perfect, I have installed 2 additional grounds and cleaned the orginal ones, tested them, I get 1.0 or less ohms , I have replaced the ELD ( electric load detector ), I have replaced the fuses all of them, I have replaced the spark plugs also, I get no warning lights on my dash, except for the SRS which has been on for way before this problem started happening.
Nov 16, 2009 at 7:04 AM
