2002 Honda Civic Gears are Stiff
95,000 MILES • 6 CYL • FWD • MANUAL
TAUSEEFAKHAN
I have just bought this Honda Civic Coupe 2002 - I have got a problem with gears - 2nd and 4th gears are bit stiff - It drives ok but when you change gears 2nd and 4th gears are stiff - 4th gear is more stiffer than 2nd. You have push it hard to get into that gear. Any ideas why this could be....... is it due to clutch or gear box is gone. Would appreciate your help. Many Thanks.
Mar 8, 2009 at 11:16 PM
KHLOW2008
  • 41,812 POSTS
Hi tauseefakhan,
Since it is only affecting the 2nd and 4th gear, it should be a gear shift cable fault. I believe reverse should not be easy to engage as well.
Mar 14, 2009 at 9:38 PM
TAUSEEFAKHAN
Thanks for your time, Reverse is fine. Many Thanks
Mar 15, 2009 at 10:39 AM
KHLOW2008
  • 41,812 POSTS
Are you able to shift into 2nd and 4th easily when engine is not started?
Mar 17, 2009 at 1:08 AM
THEG0202
Hi there,
I have a similar issue I would like some help with. I have a 2001 Civic Coupe with about 90K mi on it.
Switching in 2nd, 3rd and 4th is a little difficult. The movement is not smooth b/w gears and if I put it in neutral for a moment and then shift into gear, then it's ok. Like you suggested, sometimes, shifting into reverse is a problem too.
Do you still reckon its a gear shift cable fault? Is this expensive to replace and get installed?
Thanks for your time!
Oct 23, 2009 at 1:15 AM
KHLOW2008
  • 41,812 POSTS
Hi TheG0202,
With so many gears in question, it should not be a gear shift cable fault.
When engine is not started, are all the gears easy to shift into?
When engine is started, with vehicle stationary, is it easy to engage every gear? You must release the clutch before engaging the next gear.
When vehicle is moving, does up shifting from 2 to 3 and 3 to 4 becomes difficult with signs of gears crashing?
Are the symptoms similar or more pronounced when down shifting?
When was the last time you replaced the trans gear oil?
If it was recent, was the correct type of oil used?
Oct 23, 2009 at 2:50 AM
THEG0202
Hi KHLow2008,
With the engine off, it's still hard to shift into the gears.
With the engine on, it's the same - gears are resisting (releasing the clutch each time).
I find that when I transition from 2nd-3rd or 3rd-4th, it resists, but then, if I bring it back to neutral and then go into 3rd of 4th, it transitions normally. The transmission feels like the gear is being resisted from going into its full position, i.e. resisting.
Finally, there doesn't seem to be any difference when down-shifting.
I bought the car used about 6 months ago (I live in Houston) so not too sure if/when the transmission oil was changed or what was last used.
Thanks for your help!
Oct 23, 2009 at 3:27 AM
KHLOW2008
  • 41,812 POSTS
If the gear shift seems very loose and has a lot of free travel, the linkage is bad and you would have to check for worn bushes.
I believe it is not going to be too costly to repair it.
Oct 23, 2009 at 5:07 AM
