2002 Honda Civic ERROR CODES 1298 AND 1457
40,000 MILES • 4 CYL • FWD • AUTOMATIC
SMKARIUKI
I got a check engine light and went over to strauss auto... the technician said that he found the fuel cap loose, he tightened it and reset the computer.. the two codes disappeared, but came back after two days (after doing about 60 miles). Could they be possibly related? what is the best thing to do so as to fix this issue...
Oct 9, 2008 at 7:45 AM
KHLOW2008
  • 41,812 POSTS
Hi smkariuki,
P1298 = Electrical Load Detector circuit high voltage. You need to check/test the ELD and its wiring circuit.
P1457 = Evap System Leaks. It could be the gas cap but more likely to be the canister or its connectioon that is leaking.
Oct 15, 2008 at 8:44 AM
