Cruise Control
STOWMAN47
Electrical problem 4 cyl Two Wheel Drive Manual 91000 miles
I spilled some juice on the steering wheel and the cruise control stopped working. I changed the switch that is attached to the steering wheel, but, it didn't fix the problem. Got any ideas?
Jan 2, 2009 at 8:27 AM
KHLOW2008
  • 41,812 POSTS
Hi stowman47,
Does the main switch light shows when switch is turned on? Other things to check are : Check the No. 10 (7.5A) and No. 4 (10A) fuses in the under- dash fuse/relay box, and the No. 7 (15A) fuse in the under-hood fuse/relay box. Check that the horn sounds. Check the tachometer to see if it works properly.
Here are some guides and a cruise control wiring diagram so you can check the connections.
and
Check out the diagrams (Below)
Please let us know what you find.
Cheers, Ken
Jan 2, 2009 at 9:43 AM
STOWMAN47
RE: Cruise stopped working after juice was spilled on Steering Wheel.... Changed Wheel Mtd. Switch, did not help...You suggested checking fuses #10, 4, & Under hood #7. All of them are ok. The horn works and the tach is fine....Any other ideas?
Jan 3, 2009 at 2:59 AM
KHLOW2008
  • 41,812 POSTS
Hi stowman47,
If I were you it sounds like the brake light switch has gone bad which will cause the cruise control to stop working. Here is a diagram to help you get it changed out.
Cheers, Ken
Jan 3, 2009 at 10:13 AM
