2002 Honda Civic Codes
139,000 MILES • 4 CYL • 2WD • MANUAL
VESSAFLY
I was given 3 dt codes. P1298- Lean operation @ wide open throttle, P1259- VTEC system malfunction, and P0600- Serial communication link malfunction. My malfunction indicator light has been going on/off for a couple of weeks. I can do the work, i just need someone to translate this into plain English for me please.
May 26, 2008 at 10:49 AM
KHLOW2008
  • 41,812 POSTS
I believe P0600 is causing the other 2 problems. Check for loose ECU connectors but you might have a faulty ECU.
May 27, 2008 at 3:27 AM
