2002 Honda Civic Check Engine Light - O2 bypass solenoid Mo
106,500 MILES • 4 CYL • FWD • MANUAL
DIYDAVE
Check engine light came on for approx 1 week. Went off for approx 3 days then returned.
Took it to dealer and their diagnosis is a failed O2 bypass solenoid module. Dealer cost to repair is $790.00 parts, labor and tax. No change in performance - gas mileage slightly improved.
What harm if I don't replace it? Any effect on PCM?
Where is the part located on the car and how difficult to replace? Does the PCM require reprograming & is that a dealer only procedure?
Where can I down load a procedure to fix this myself?
Apr 7, 2009 at 5:38 AM
BMRFIXIT
  • 19,053 POSTS
To better assist you need to have what you have for codes
as I can not think of any thing called O2 bypass solenoid module
Apr 7, 2009 at 1:44 PM
