2002 Honda Civic changing out turn signal switch
USASTARFLEX
Electrical problem
2002 Honda Civic Front Wheel Drive Automatic
How do I change out the head light and turn signal light switch on the steering wheel ?
Sep 1, 2010 at 9:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1.Disable the air bag system,
2.Disconnect the negative battery cable.
3.Remove the driver-s side lower dashboard cover and knee bolster.
4.Remove the steering column covers.
5.Remove the steering wheel
6.Disconnect the harness by gently depressing the tab on the connector and pulling.
7.Remove the combination switch mounting screws, then remove the switch.
8.Installation is the reverse of the removal procedure.
Sep 1, 2010 at 12:04 PM
