When I release the brake pedal, I hear a short high pitch sounding squeak. Any ideas? Thanks for your help!!
Jun 27, 2008 at 3:33 PM
KHLOW2008
✓ASE Certified Mechanic
Hi refpoman,
Depends from where the noise is coming from.
Pedal = pedal linkages needs some oiling.
Rear = if drum brakes, the shoes seat are dry, needs some lubrication.
Jun 28, 2008 at 9:16 AM
REFPOMAN
MEMBER
The squeak is coming from the rear. How do I go about lubricating the drum brakes shoes seat?
Thanks!
Jun 28, 2008 at 7:18 PM
KHLOW2008
Hi refpoman,
You need to remove the rear wheels and brake drums.
Remove the the shoe locking pins and move shoes away from seat, 3 areas x 2 shoes to apply the grease. Use silicone grease and DO NOT over apply taking care that none gets to the shoe linings.
At the mileage indicated, you might need to replace the shoes.
Jun 28, 2008 at 8:44 PM
